zrevival Posted February 28, 2009 Posted February 28, 2009 Have a really badly leaking poptop sunroof in my 260 2+2 Interesting - the rubber condition looks ok. Does anyone know the procedure to fix this? Quote
reverendzed Posted February 28, 2009 Posted February 28, 2009 Does anyone know the procedure to fix this? Mig welder! ...otherwise check your adjustments on the latch mechanism to see if it will pull it down tighter. rev. Quote
zrevival Posted February 28, 2009 Author Posted February 28, 2009 Actually don't mind having a sunroof - so removing it at this stage wasn't on the cards. Thanks for the advise on the latch Rev - I'll have a look at Quote
xa1973 Posted March 1, 2009 Posted March 1, 2009 Hello Mate Change out the rubber seal, regardless that it may LOOK ok, rubber loses its substance after a while, check the roof in case its warped and as said before adjust the latch and hinges Cheers Quote
zrevival Posted March 6, 2009 Author Posted March 6, 2009 Took the sunroof apart, retightened all the screws and it now seems to seal real well. Thanks for the help Quote
