Does anyone here know much about RB30's? I have some problems with one.
First I checked fuel pump, not working. Replace and check that its getting to the fuel rail.
Then check spark, ok.
Check half a dozen other things but it still won't fire.
Everything seems to be working except the injectors.
I have ECU error codes 14, 23, 24, 31 and 32.
Can anyone tell me what they are?
Found this on another forum after a google of
ECU error codes 14, 23, 24, 31 and 32 Rb30
Those codes are normal.....
Code 14 is your speed sensor circuit, cancel that out by driving the vehicle at speed greater than 10kph
23 is your TPS, cancel it by switching the car off then back to the on position and fully depress then release the throttle.
24 is the neutral switch on your auto, move it down to first then back up to neutral to cancel this
31 is a system pass for a non airconditioned VL, yours has A/C so it's a a/c circuit, just switch your a/c on then off to cancel.
After this you 'should' be left with a code 44, which is system pass for an air conditioned VL.
