Hi all,
I'm looking for a replacement fuel sending unit for a 07/81 280ZX on behalf of the owner in Tasmania.  His current one is not reading above 1/4 full and he was told by his mechanic to source another unit or find a fuel tank to scavenge one out of.  If anybody has one or has some leads on where to go for one it would be much appreciated.
If there's some guru advice out from someone who's had this issue and fixed it themselves I'd love to hear from you.
Scott
Posted (edited)
Pull it out & clean it.
Re-adjust it's range - this can be done out of the tank - it should have a Ohm range of 10 to 90ohms.
If it is stuffed, try genuine Nissan for a new one.
Edited by C.A.R.
Cheers Lachlan.
