Scootytooty Posted March 29, 2022 Posted March 29, 2022 Hi all, I'm looking for a replacement fuel sending unit for a 07/81 280ZX on behalf of the owner in Tasmania. His current one is not reading above 1/4 full and he was told by his mechanic to source another unit or find a fuel tank to scavenge one out of. If anybody has one or has some leads on where to go for one it would be much appreciated. If there's some guru advice out from someone who's had this issue and fixed it themselves I'd love to hear from you. Scott Quote
C.A.R. Posted March 29, 2022 Posted March 29, 2022 (edited) Pull it out & clean it. Re-adjust it's range - this can be done out of the tank - it should have a Ohm range of 10 to 90ohms. If it is stuffed, try genuine Nissan for a new one. Edited March 29, 2022 by C.A.R. rubberman and gav240z 2 Quote
Scootytooty Posted March 30, 2022 Author Posted March 30, 2022 10 hours ago, C.A.R. said: Pull it out & clean it. Re-adjust it's range - this can be done out of the tank - it should have a Ohm range of 10 to 90ohms. If it is stuffed, try genuine Nissan for a new one. Cheers Lachlan. Quote
rubberman Posted March 31, 2022 Posted March 31, 2022 I had the same issue, tried to buy one but none available so had to go down the rebuild path. Came up well. Quote
