psyosphere Posted July 18, 2008 Posted July 18, 2008 Hi guys The last problem that im now facing is when im cranking over the motor. When i turn it over the cranking slows right down for 1 revolution and then give in acouple of minutes and it returns back to how it normally cranks like has anyone got any ideas to what is happening... (im using points & coil) Quote
pauly_adams Posted July 18, 2008 Posted July 18, 2008 is this a recent problem, when i changed my dizzy my firing order went out and fixed it and it was all good. good luck cheers pauly Quote
Moderators Zedman240® Posted July 18, 2008 Moderators Posted July 18, 2008 I'd put a voltmeter across the battery while you are cranking and see the volts. If its below 10, the battery is flat or farked. Batteries can do magical things when they are about to fail... Quote
C.A.R. Posted July 18, 2008 Posted July 18, 2008 I'd put a voltmeter across the battery while you are cranking and see the volts. If its below 10, the battery is flat or farked. Batteries can do magical things when they are about to fail... +1 Quote
