Unlikely anyone in Australia will have reproduction late 260Z floor pans.
You may have to import a pan from the USA for a 280Z.
They don't rust as badly as 240Z floors, so how bad is the rust? Do you have photos?
They could probably be repaired...
So, it was pretty bad. The previous owner had patched holes with fiberglass. So I went and cut all the bad parts out. I've now had it sitting like this for a few months, and I'm not sure how I'm going to replace the floor. I have sheet metal and a mig welder but I'm thinking theres gotta be a better way to do this.. any advice here is welcome.
Ahhh that's problematic, but not unrepairable.
I suggest you follows Paul's tutorial as a guide:
Take a paper template from the same area on the drives side,
flip/mirror the pattern, then mark it out on some fresh sheet steel and start fabricating :)
