I am wondering if anyone has ever run duel weber carbs? I have a fully rekitted pair of Weber 32/36 DGV carbs and matching manifold and K& N Filters, I also have a nice set of 240z SU's and when we drop the new motor in (2 weeks time)I need to determine what the best option will be.  The motor build is an L28 that has been fitted with flat top pistons, (hopefully) streetable cam, portmatched, balanced and blueprinted there's probably more stuff but I can't remember!  If I go with the SU's I need to get them rekitted or the other weber's are ready to go....can anyone help with this?
Found out I am missing a small piece of linkage for the Webers does anyone know where I could possible source Carb Parts on the S.E side of Melbourne?
Rev.
I'm missing the part in the pic! I think it is one of the linkages that is part of the throttle body (which opens the butterfly part in the carby throat)it  is missing the small spring and attaching piece,
If you don't have much luck Rev, you might be able to find one at a self serve wrecker. I think some early XE/XF Fords used DGAV Webers (among other things). I need to go to one near me this weekend so if I spot one, I'll grab it.
  • 2 weeks later...
Guys....I'm in a bit of trouble my new motor and gearbox get fitted this week (Saturday) and I still can't source the part I need which is part of the manual choke.  If anyone has any webers of any sort with a manual choke could I borrow/buy the part I need.  I've been to a number of carb shops with no luck.  Thanks
Rev.
My bro has one which i can borrow and send to you. We can figure out the rest from there.
PM me  ;D
And i might be in M<elbourne on Saturday
