chris240 Posted May 31, 2008 Posted May 31, 2008 I swaped the guts from a km/h speedo into my Mp/hr speedo casing , all went fairly well, hooked up speedo cable, managed to tighten the wing nuts after a 15 minute struggle, and took it for a drive. The speedo worked until I got to the bottom of the street, then seemed to die when a took off from a stop sign...any thoughts ? could there be an incompatibilty problem ? The speedo mechanicals from 240 & 260z speedos look identical. got me stumped. Quote
rosco Posted May 31, 2008 Posted May 31, 2008 Hi chris. Ill probably check the speedo cable first before doing anything else. If the speedo was working and then it stoped that could be the problem. Quote
Moderators Zedman240® Posted May 31, 2008 Moderators Posted May 31, 2008 When you re-attached the speedo cable to the back of the guage, did it go on completely? From memory it takes quite a few turns to tighten it up. Also rosco is right; check and make sure your cable hasn't broken. I was driving one day and my speedo just dropped from 60-0 in less than a second....When it came time to check, I had a two piece cable... Quote
chris240 Posted May 31, 2008 Author Posted May 31, 2008 thanks , i'll check the cable hasnt snapped. Yeah it did take a few turns, but Im sure I screwed it on properly. I also lost power to the 2 small 3 watt globes that iluminate the speedo...the high beam & red stop light where ok... great , another day with my head under the dash. my back is killing me !! Quote
