scotta Posted July 31, 2018 Posted July 31, 2018 I’m looking for a bonnet latch for a 72 Fairlady Z. (Same as the 240z latch) male and female parts. (I do not need the cable) Quote
Groundhog Posted August 1, 2018 Posted August 1, 2018 Be aware that catches on LHD and RHD cars are opposite handed due to the pull cable coming from the other side. Quote
scotta Posted August 10, 2018 Author Posted August 10, 2018 On 8/1/2018 at 5:54 AM, Groundhog said: Be aware that catches on LHD and RHD cars are opposite handed due to the pull cable coming from the other side. Whilst I’m based in the US I have a RHD version car, that’s why I’m reaching out to Aust for the right version. Quote
Gtv240z Posted August 12, 2018 Posted August 12, 2018 I'm could be wrong but I thought I read some where that if you disassemble the latching mechanism and reverse a certain part it will work in opposite direction Quote
Groundhog Posted August 12, 2018 Posted August 12, 2018 I've made a zRHD latch into a LHD latch. I.made a new hook as the tab to release has to be bent 180the other way. The part with the pastic coating. There is also a high side and low side on the base plate where the spring retainer holes are. You can do it but a purist would spot the difference. If you want one to modify PM me. Quote
Groundhog Posted August 12, 2018 Posted August 12, 2018 The early bonnet latches had the pivot pin in a pressed out section of the channel bent 90 degrees. THis was a weak point and in later bonnet latches they spot welded in the hinge. You can see the spot welded section and hinge. Quote
