Gtv240z Posted March 17, 2018 Posted March 17, 2018 Here we have a base mounting bracket for the above mentioned dizzy. I pulled apart the dizzy to inspect as there were a couple of loose ball bearing floating inside. Ball cage mechanism broken and vac unit also unserviceable.. The base mount appears different to traditional 240z 260z points mount bracket so may be of some use to some one $20 Quote
