aircobra Posted July 10, 2017 Posted July 10, 2017 does anyone have one ? my unit is in real tight and i don;t want to wreck it screwdriver bashing thanks in advance Quote
ScottyD Posted July 11, 2017 Posted July 11, 2017 If you can't get one try to make one http://woodworkerb.com/home/datsun-240z-rebuild/240z-fuel-tank/ Quote
44014 Posted July 11, 2017 Posted July 11, 2017 does anyone have one ? my unit is in real tight and i don;t want to wreck it screwdriver bashing thanks in advance Large brass punch and just give each tab a good solid hit and it will move. Quote
aircobra Posted July 11, 2017 Author Posted July 11, 2017 that did it. because the car was standing for a long time, had some corrosion on the wire terminals on the inside of the sender. would have to be the world's simplest device - just a coil of wire and a brass slider. some carb fluid and an acetone soak fixed it saved $100 for a new one. getting closer to finishing every day Quote
260DET Posted July 11, 2017 Posted July 11, 2017 It's normal practice with anything like that on an older car to hit it with some penetrating oil first. Quote
