Groundhog Posted June 4, 2017 Posted June 4, 2017 Has anyone found a suitable replacement for the plastic cover that contains the headlight wiring? It is the black plastic sheath that the wiring is placed in. Mine is brittle and cracked.I am also chasing the grommets that go in the rear of the headlight shell and where the wiring passes through the inner guard. Quote
gilltech Posted June 5, 2017 Posted June 5, 2017 Wiring grommets to headlamp shell? Clarke Rubber do a range of grommets. Quote
PeterH Posted June 5, 2017 Posted June 5, 2017 http://www.240zrubberparts.com/apps/webstore/products/show/5507024 is this the sort of thing that you are after? Quote
Groundhog Posted June 5, 2017 Author Posted June 5, 2017 (edited) Yes. Thanks. The wire sleeve and the two grommets are the same as what I am after.I will try an alternative Japanese parts importer to see if other makes and models use the same grommets and wire sleeves before I try and order overseas. EDITFound this website which has exactly what I am after. http://www.cycleterminal.com/sleeve-tubing.html And these guys too. Check the Insulation catalogue https://jaydeeautocables.com.au/catalogue-2 Edited June 6, 2017 by Groundhog Quote
