Posted (edited)
Datsun 240Z 260Z Manual Gearbox Conversion Kit
If you want to convert your Automatic 240Z 260Z to manual transmission, this kit contains everything you need to perform the conversion.
Datsun 5-speed manual gearbox, with bell housing bolts.
Clutch & flywheel assembly.
Clutch fork & correct TO bearing carrier.
Clutch slave cylinder.
Clutch master cylinder, hard line & bracket (new rubber line is required).
Manual Pedal box.
Simply use your existing engine backing plate, tail-shaft & gearbox cross-member.
It is recommended that all parts be reconditioned.
Price: SOLD
Pickup preferred, but I can package & ship at buyers expense.
Edited by Lurch ™
