Posted (edited)
I am after the driver side retractable seat belt complete with stork and associated parts working or not.
It appears that I will not need all bits as I am looking at replacement.  However I would like to use the metal guide bar in the new seat belt makeup so I need the drivers side metal guide if any one has one and that should get me out of trouble.
Edited by redzee
Well I have taken some pics and the description of the set up is the retractable unit is bolted to the top of the rear strut on a bracket.   The belt is fed through loop in a metal bracket that is bolted to the roof and under the side window.  Then it is secured to the floor behind the seat.   To fasten the belt it is drawn across the torso and fastened to a stork that is bolted to the transmission tunnel.
It's the location of the retractor which is key, some were fixed lower on the wheel arch, some on the strut, the internals can differ depending on the belt angles.
