So I'm rebuilding my Brake Master Cylinder as it's leaking fluid out the back of it (onto the booster) and I'm wondering where I would find the rubber seals as well as all the other components needed.
Cheers,
Andrew
Hi Andrew,
Personally it would probably be better to get a new unit as it could be the bore worn as well as not only the seals. 7/8" master cylinders are easy to come by new and not badly priced.
Otherwise check out one of the brake and clutch places as they might be able to match up the seals.
Justin
