aircobra Posted February 12, 2017 Posted February 12, 2017 this stuff will work fine? http://www.supercheapauto.com.au/Product/Penrite-Gear-Oil-80W-90-2-5-Litre/342306 Quote
Bluebird68 Posted February 13, 2017 Posted February 13, 2017 this stuff will work fine? http://www.supercheapauto.com.au/Product/Penrite-Gear-Oil-80W-90-2-5-Litre/342306 no it wont, thats gl-5 should be gl-4 Quote
C.A.R. Posted February 13, 2017 Posted February 13, 2017 (edited) Castrol VMX-80 for the gearbox (GL4) Castrol EPX 80W90 for the diff. Further reading: http://www.ozdat.com/forum/viewtopic.php?f=29&t=34169 Edited February 13, 2017 by Lurch ™ 24TZ 1 Quote
aircobra Posted February 13, 2017 Author Posted February 13, 2017 manual for the dif (pd3 says GL5) and 1L CASTROL AXLE EPX 80W-90 is GL5 - seems the same specs as the penrite gearbox is listed as GL4 (1.7l), so 2 of these should do http://www.supercheapauto.com.au/Product/Castrol-VMX-80-Transaxle-Manual-Transmission-Fluid-1-Litre/1582 i wonder why the penrite right says good for gearbox and diff? Quote
pauly_adams Posted February 15, 2017 Posted February 15, 2017 that is the correct oil to use when using penrite mate, being GL5 will not hurt it it just has a few extra additives Quote
