Posted (edited)
Any one know of an easy fix for the temp and oil pressure guage cluster in my 240z . Both are reading very low and some times zero. When they are working they fluctuate up and down slowly . Both senders test ok . When both sender wires earthed out with ign on eng off both guages come up to quarter for about 15 secs then fluctuate and drop to zero.
Edited by MyEnquiringMind
All fixed, the fault was the gauge. I ended up pulling the gauge face off to check the bimetallic strips inside. There are three of them one for each gauge and one with an adjustable contact on the end. The contact was dirty, gave it a light rub with 800 grit paper and now both go full gauge with sender wire earthed out.
