dat2kman Posted July 11, 2016 Posted July 11, 2016 Quantity of (5) standard L6 camshafts, all are original factory spec, this means you can send them off for a fresh regrind! Usually can get 68 to 72 degree "street/track" spec grind out of them. $90 per Rocker arms, brand new, genuine Nissan, along with good condition used rockers. $45/$15 per. Heavy duty valve springs, (110 lb seat pressure) used but still plenty of life! $100 set of 12 Can pack and post all items. Quote
Administrators gav240z Posted July 11, 2016 Administrators Posted July 11, 2016 Might be good to clarify if the camshafts are the externally oiled spray bar type or the internally oiled sort. I know Les Collins needed a few of the latter a while back.. Ran out of them. Quote
dat2kman Posted July 12, 2016 Author Posted July 12, 2016 Have 4 only left, They are all internal oiled units, ie no need for a spay bar. If you require later type towers, to suit internal oil feed cams, have these as well. Quote
