phillay Posted April 14, 2016 Posted April 14, 2016 (edited) selling my triple 40mm mikuni carbs with manifold, linkages, and trumpets.these has been taken apart three times, rebuilt and throttle shafts replaced then tuned with the help of a mikuni expert in melbourne in Jan 2016, I had this on my L28 but i think they are more suited to an L24 or L26, i wasn't 100% with the power, but it drives well. A lot of time was spent on these to have it running with a idle of 1000rpm as these older mikuni have problems with the metal type that was used. They were put on a heater to be heated up to 60 degrees or something and then installed on the car and then checked and tuned. I wanted to replace this with a set of 44s but i was getting over the amount of waiting time as it takes ages to find a good set to start off with and then waiting for the mikuni man to work on them as there's a huge queue for his service.the trumpets are from efi hardware SOLD Edited April 23, 2016 by phillay Quote
PriceyZed Posted April 14, 2016 Posted April 14, 2016 G'day Phillay, I've just bought a set of 40mm mikuni's and was wondering who in melbourne you used to tune them??? I'm planning on using a fairly lumpy cam for my build, and I'm stressing that the 40mm carbs wwill not be able to keep up. Is your L28 standard or modified? Cheers Dan Quote
C.A.R. Posted April 14, 2016 Posted April 14, 2016 G'day Phillay, I've just bought a set of 40mm mikuni's and was wondering who in melbourne you used to tune them??? I'm planning on using a fairly lumpy cam for my build, and I'm stressing that the 40mm carbs wwill not be able to keep up. Is your L28 standard or modified? Cheers Dan Correct. 40mm triple carbs are NOT suited to a warm L28. Sell them & buy some 45mm triples. Quote
phillay Posted April 14, 2016 Author Posted April 14, 2016 G'day Phillay, I've just bought a set of 40mm mikuni's and was wondering who in melbourne you used to tune them??? I'm planning on using a fairly lumpy cam for my build, and I'm stressing that the 40mm carbs wwill not be able to keep up. Is your L28 standard or modified? Cheers Dan Lou Mondello tuned mine, he made me took the thing apart at his shop with his tools and then he did the bits that were important and helped me fix anything that needed attention. He is a very skilled and knowledgeable man, because of this he is very busy and hard to access. As lurch said, 40mm will not be able to keep up, I was contemplating should I pick up a set of OERs as I was going to japan for a holiday, but after some guidance from various people. Webers were the go for the easy to access parts locally and consistent build quality. Quote
PriceyZed Posted April 15, 2016 Posted April 15, 2016 Thanks for the advice Lurch and Phillay. I'll have to offload my Mikuni's and chase some webers then Quote
