Administrators gav240z Posted April 12, 2015 Administrators Posted April 12, 2015 Hi guys, Got a couple of gauges here that I don't need and figure someone might need them? Early 240z (70-71) water temp and oil pressure gauge. The early ones have an extra delimiter in the middle of each respective gauge. Later ones simply had the start and end markers. Price: $50 Next up... 260z/S31 amp /fuel gauge, these were only fitted for 1 year as far as I'm aware. 1974. You can tell it's a later style gauge because of the single loom plug (240z has separate plug for light bulb and gauge) and the bracket on the rear suits the 260z dash mount. Price: $50 Both prices are negotiable. Quote
YosemiteZed Posted April 12, 2015 Posted April 12, 2015 Just a note If anybody is thinking of installing the amp gauge you will also need the shunt resistor that is in a metal case that installed in the engine bay near the fuse links this is an important part for the gauge to work properly. Cheers Quote
