Hi all,
Thought I'd advrtise these here first before fleabay, I have a pair of Velo seats, both wide versions, the passenger side FIA approved, with Sparco 3" wide harnesses. Passenger side is out of date, but the drivers is either close to that but from memory is still fine for club sprints. These alone were worth $1400 but obviously not that much anymore; these are very good quality and without any incidents. Come with DIY alloy mounts to fit a 240Z. To fit in a 260Z, you will either have to modify or make your own. Drivers has a bit of wear as can be seen in the pic on the side and belt holes in the back. Passenger side is in excellent condition as it was hardly used. All these new would be around $2300, asking $650. Can help with freight if needed. We can do a E-Go depot to depot thing which should be pretty cheap.
BTW, the seats are black; just look lightish because of the camera phone!!
