First upload your pics to a web site like www.photobucket.com. Once uploaded and want to insert in a message the easiest way is to click the 'insert image' button which is the button with a small gold picture frame (above the smileys, 2nd from left, next to the globe picture button thingy). Then this will appear: [/img]. Your uploaded pics on Photobucket will show links underneath them: image code, direct html. I think its them image code link or the one with '(img)' at the start of the link. Copy and paste the link in between the (img). I think on Photobucket the image code link has got the (img) bit already so just copy and paste the link in your reply.
I hope that made sense! Hahaha
Hi
You do not need to go to the trouble of uploading to another site first. When you are creating your message there is a "+ Additional Options" button near the lower left corner of the message window. Click on that and you can attach a photo that is stored on your PC by using the browse button. The photo will get uploaded from your PC when you it the post key, but it must be less than 256Kb, so you may need to use another program to reduce the file size. Usually "save for the web" option in the photo manipulation program will do the trick.
Warren
