Hey guys,
I've seen rust repair panels for front guards getting around online. Has anyone used these?
What's im most curious about is do these have the bolt holes in the bottom where they bolt back to the chassis/body?
As I'm finding it hard to locate a drivers side guard so thinking this may be a better option.
Any info would be great.
Aaron
Just drill holes if they are not already in there. I fabricated the lower section of my guards and copied the holes over from a paper template I'm sure the rare spares lower section has the holes but if not that is the easiest part to do. The door skins are pretty good quality so I don't see why the lower fender section wouldn't be.
Thanks Gav!
I'll had a look at doing that, I might have to make the template off the body though as the holes in the old guard almost don't exist now as it had been welded on at the bottom.
You can see what it looks like here:
http://www.viczcar.com/forum/index.php/topic,13624.msg151581.html#msg151581
However it's possible that the original holes may look different and my guard could have been modified at some point to make it fit etc.. So I may have copied modified holes. Not that it's a big deal mind you.
Hence I wouldn't stress about it so long as they line up with the bolt holes you'll be fine. Of course if your goal is concourse then maybe buy new OEM guards.
Awesome thanks Gav!
I'll have a decent read through of it after but I think that's the way I will go.....
Now the big question does anyone want to do the welding work for me? More than happy to pay for it.
Welding equipment isn't something I own and not one of my strongest skills.
Awesome thanks Gav!
Only way to learn is to give it a go. Mig welders are pretty forgiving if you have it on the correct setting. I somewhat prefer the old school oxy as it's a bit neater, but I still haven't mastered it. TIG would be awesome if you wanted to buy 1 and can afford it. It's 1 skill I'm glad I've started to learn, so useful. It's the kind of skill that once you start doing stuff you find more ways to apply it ;).
For example I modified a pair of seat rails for my RX-7.
http://www.fdrx7.com/forum/showthread.php?t=16961
Which I would never have been able to do before I started the tafe course.
Of course if you don't want to learn or have the time for it that's fine also. Just encouraging others as I always wanted to learn but was afraid to give it a try.
I did a welding course when I did my mechanics apprenticeship, I don't mind welding and can do it if I need to but at this stage I just don't have the room in the garage for more stuff haha plus it's not something I can see a real long term use for currently.
Down the track though I wouldn't mind getting a Mig through work to have just in case.
