If you can't let me know? I could probably get a good pair but they cost anywhere from 200 400 AU.
Thanks I'll try get the one flute first, I know where I lost it on a rally special stage last month figured someone would of ran over it or souvenired it,
I'd be wanting a whole bonnet for $200+
Ok so I found these also.
http://www.thezstore.com/page/TZS/PROD/classic02d/30-7091A
http://www.ebay.com/itm/77-78-Datsun-280z-hood-louvers-hood-vents-/231450196658
FYI: I'm looking to either modify my fluted bonnet by cutting the vents out and welding in new sheet metal to make a non-fluted bonnet. Or I'm going to swap it for a non-fluted bonnet. Only problem is it's missing the rain tray on 1 side and the fastener on 1 or 2 corners has come off / snapped.
If someone has a black non-vented bonnet in good shape I'd happily swap it. I can't stand the vented hoods. :P
I agree, you should find yourself a 240z bonnet, the vented doesn't look right unless on a late 260z.
AFAIK, the drivers side vent has never had a rain tray. I don't have one on mine and I have never seen a vented bonnet with one on the drivers side.
I prefer the unfluted, this bonnet is FGR so i curse the PO who went and cut out thoses holes.
I do have a spare steel fluted bonnet and no the driver has no tray, stupid when the plugs and fuse links are under it.
