Hi guys,
Probably a silly question but I've got dash lights working for the 3 gauges in the centre (eg fuel gauge, temp) but not on the 2 in front of the steering wheel eg Speedo...
Any ideas?
Hi guys,
Any ideas?
Each gauge has its own bulb/s have you checked the bulbs for the speedo & tacho ?
If the bulbs test OK check for 12V at the bulb socket (with the headlights on  ;)  )
Also make sure the bulb sockets are clean and the bulb is a snug fit
Good luck
PB
The bulb holders in the gauges have small metal "tabs" that earth on the metal gauge body itself so if that's not earthing, no bulb will be on. I have that same problem on my 240 as only the clock lights up even though I have replaced every globe when the dash was out. Looks like I have to remove it again and fix a few issues while its out.
