mattc Posted July 8, 2014 Posted July 8, 2014 Hi guys, Probably a silly question but I've got dash lights working for the 3 gauges in the centre (eg fuel gauge, temp) but not on the 2 in front of the steering wheel eg Speedo... Any ideas? Quote
Moderators PB260Z Posted July 8, 2014 Moderators Posted July 8, 2014 Hi guys, Probably a silly question but I've got dash lights working for the 3 gauges in the centre (eg fuel gauge, temp) but not on the 2 in front of the steering wheel eg Speedo... Any ideas? Each gauge has its own bulb/s have you checked the bulbs for the speedo & tacho ? If the bulbs test OK check for 12V at the bulb socket (with the headlights on ) Also make sure the bulb sockets are clean and the bulb is a snug fit Good luck Cheers PB Quote
Moderators Zedman240® Posted July 8, 2014 Moderators Posted July 8, 2014 The bulb holders in the gauges have small metal "tabs" that earth on the metal gauge body itself so if that's not earthing, no bulb will be on. I have that same problem on my 240 as only the clock lights up even though I have replaced every globe when the dash was out. Looks like I have to remove it again and fix a few issues while its out. Quote
