adam Posted June 23, 2014 Posted June 23, 2014 Hi all, I am after an L series flywheel to suit my L28. I have a 225mm unit at the moment but hairline stress cracks have appeared and would like to replace this with a 240mm item ideally, but would settle for a 225mm. I am not after an RB series flywheel as their center bore is larger than what an L series crank requires. Pickup in Melbourne preferred as I need it quite urgently. Let me know what you've got or any suggestions you may have! Thanks, Adam Quote
C.A.R. Posted June 23, 2014 Posted June 23, 2014 The hairline stress cracks on the friction surface are quite common. Just have the face re-machined & it'll be a good as new again. Quote
adam Posted June 25, 2014 Author Posted June 25, 2014 The shop I took it to was able to machine out all the hairline cracks which is a bonus! Thread can be closed. Thanks Quote
