Eric Posted May 13, 2014 Posted May 13, 2014 This has been killing me a long time. I have a non- turbo 82 that I got running after I had unblocked the sender unit. Then I let it sit unstarted for a month as I did body work to it. It doesn't start now that I discovered that a cat for something had ripped 1 of the 2 wires out of the fuel pump. Now I have bought a new fuel pump replace the fuel pump relay under the dash and in the engine bay. But it still doesn't pump fuel. I am now ripping the car apart looking for a fuse as diagrams in the manual say there is in part of the circuit but doesn't give to any clue to where they are. :'( Quote
Moderators Zedman240® Posted May 13, 2014 Moderators Posted May 13, 2014 Grab a test light and start probing for 12V, check at the realy, plugs then at the pump. Make sure its getting power before you start ripping anything apart. Quote
Moderators PB260Z Posted May 13, 2014 Moderators Posted May 13, 2014 The EFI workshop manual has a pretty good trouble shooting section. If you don't have a copy shoot me a PM with your email and I will send a copy through. Cheers PB Quote
