So I was going to keep these for future 3D printing purposes but I figure if someone can put them to good use then I might as well offer them up here. I couldn't sell them because a couple of them were given to me with a collection of other bits and pieces and I figure it's better to give them a good home. If you have anything to give me of use in return I'd appreciate it, but not required.
Would prefer to give to a Sydney member since I won't have to post it (can give it to someone at a meet etc..) but I'll consider posting also.
Center Console Finisher Trim #1
This came out of HS30 00150 - it's genuinely 44 years old ;)
I painted the edges white as part of experimenting with how it would turn out. But it needs a bit more help than that to 'restore it'.
Center Console Finisher Trim #2
Mark (mossy) gave this to me, it would be ok if not for some genius' idea to cut holes in it :S
Astray surround.
It's split in 2 pieces, but the break is clean and could be epoxy / glued back together and painted and you wouldn't even be able to tell once installed.
It's missing some of the hardware/clips and the ash-tray chrome bit inside the ash tray that helps.
It comes with a lid that has been broken many times before and I recently glued back together with epoxy resin (top right corner) which seems to hold very well.
Is is however missing the lid handle part. The ash-tray surround comes with a chrome trim ring (I broke 1 of the 3 tabs on it, so it has 2 left).
You don't want to know how much a center console ash-tray for an early S30Z is new these days.
I've seen them as high as $450 on eBay.
http://jdm-car-parts.com/item-for-sale/ash-trayfuse-cover-for-datsun-240z-series-1/
Thanks guys.
PS: First in best dressed. Only way to do these things.
No problem George. I was going to ask you, but thought it was only fair to offer it to everyone ;).
Wouldn't want it any other way.
If I can't use it I'll pass it on to someone who can.
Just hold on to it until the next meet. Cheers.
