Hi Guys,
I've got a pair of front and rear Lovell's springs for sale.  The codes for the springs are DRL-11 (lowered springs for the rear) and DFL-48 (lowered springs for the front).
I contacted Lovell's technical support a while ago to ask about the spring rate for these springs, and from memory they said about the 200lb mark, so they are stiffer than stock while not being over the top.
I'm still using Lovell's springs in my car now, but I've had to change the heights after completing a 1UZ engine conversion, hence the reason for these being for sale.  The rear springs have a minor spot of surface rust as shown in the picture, but nothing that effects the performance/operation.  If you were fussy you could paint this spot again.
Price: $50 a pair or if you take both of them $80 for both.
I'd prefer pickup from Kensington, NSW (Sydney), but can post if I don't get any local takers.  I'd estimate that they will be about $20 a pair to ship to most capital cities, but if you want an exact quote let me know your post code.
Hi,
I can help with getting them to either Melbourne, Ballarat or Adelaide if they sell to someone in those areas.
PB
Unfortunately I didn't take any measurements while these springs were in the car. It gave it a similar ride height to the photos below.  I know that may not be the biggest help, but I've realised that I never really took many photos of the car prior to pulling it apart for the engine conversion...
If you're keen the Lovell's tech support could give a better estimate of the final ride height if you can let them know your current car/setup.
Or you could look on the Lovells website.  ;)
The part numbers tell you they are L Lower = 25-40mm
Thank PB260Z I probably should have known that  :-\
Pauly, you have a PM.
750Shadow, if Pauly doesn't want them I'll let you know.
No Drama's I was sitting at Melb airport waiting for a delayed flight  :( so had plenty of time to hit up the internet for answers.
let pb260z have them im back in albury unfortunatly
Gidday
I'm not a buyer for them was killing time on Google.
PB
PS happy to help get them to Albury for you  :)
