Scoota G Posted March 20, 2014 Posted March 20, 2014 As seen in the brake modification thread i wrote. These brackets allow you to fit R31 Rear Discs to your Datsun. http://www.viczcar.com/forum/index.php/topic,9487.0.html Price is $70 a set Changeover, you post me yours and i post you a modified set back. Will pass engineering. Quote
44014 Posted March 20, 2014 Posted March 20, 2014 I should probably get a set of these. How much posted to bris ? Cheers Doug Quote
Triptych Posted March 20, 2014 Posted March 20, 2014 already got my set off Scoota and should hopefully look at starting to fit them tomorrow but that depends on how long it takes me the hack the yard up first. Quote
Scoota G Posted March 20, 2014 Author Posted March 20, 2014 I should probably get a set of these. How much posted to bris ? Cheers Doug Well i pay the postage on this end. You just send me an unmodified pair. Quote
Scoota G Posted April 1, 2014 Author Posted April 1, 2014 These brackets are copied off a control set and test fit before i send them out. Because they are modified by a human there are slight differences inbetween brackets but i match a set together to make sure they are on the correct angle. The caliper angle may vary a degree or two either way. Quote
Scoota G Posted April 1, 2014 Author Posted April 1, 2014 At any time i will have one control set and one set ready to post, this means i can post out straight away. Here's a picture of Doug's set fitted to the struts. Quote
