35 years of hoarding, collecting, buying, selling, knowing what works and what don't!
The brain is getting addled, and the eyes don't work much anymore, but i'm still usefull for something, just need to work out what!
Hmm I do actually need an oil pump as well! it was more the shaft I was asking about, since I've got the non-turbo spade-type shaft and I need to use an optical distributor for the ECU I was planning to use :)
I'll PM you ;)
Same with me have everything from hoarding, But where is it when you need it??
I'll PM you ;)
Iknow the shaft you require L20a 6 cyl turbo had the same as the L28Et , most were thrown in the bin after the import L28 boom , Zshop in Glen iris sells the distributors on ebay minus the shaft ,quotes shaft sold separately so I assume they have them
  • 3 weeks later...
