DreamZproject Posted March 13, 2013 Posted March 13, 2013 I would have thought, no way! But according to Vicroads; Application Required From 6 July 2009, drivers issued with a probationary licence on or after 1 July 2007 may drive some lower performance turbocharged or supercharged vehicles. The definition of a lower performance turbocharged or supercharged vehicle is a vehicle with 6 cylinders or less that is: turbocharged or supercharged with a power to weight ratio of less than 100kW per tonne Now i know you would have to apply... but damn, that wouldn't be bad for a P-plater considering that; 1,356 kg (2,989 lb) 2+2 (134 kW; 182 PS)) at 5,600 rpm and 203 ft•lbs (275n•m) of torque at 2,800 rpm Another consideration... was the 280zx turbo brought out here? Quote
pauly_adams Posted March 13, 2013 Posted March 13, 2013 no, and no if buts or maybies, you can apply for a exemption though but very few are granted Quote
Agno Posted March 13, 2013 Posted March 13, 2013 It has to be a factory turbo model and 100% stock to be given an exemption, which would make it a LHD American import, so not allowed. Also even if it meets the criteria you would most likely find that they will still say no because it's a sports car. Quote
DreamZproject Posted March 13, 2013 Author Posted March 13, 2013 K makes sense! i always thought we got the turbo version here.... oh well. Quote
