Casper the friendly ghost Posted January 13, 2015 Share Posted January 13, 2015 like it says.. Im after a gasket/repair kit for my 1982 280zx hitachi A/C compressor.. Its working fine but has a small oil leak + a bearing/grinding noise when switched on.. searched and googled.. but cant find anything.. Thanks casper Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted January 13, 2015 Moderators Share Posted January 13, 2015 Hi Mate Might be worth swinging past the local Auto A/C guy and getting the source of the grinding confirmed, is it the clutch unit or the compressor itself ? Don't forget that with just about any work on the A/C you will be up for a regas afterwards and for that you will most likely need expert help, could be quicker and more efficient to give them the entire job ? Cheers PB Quote Link to comment Share on other sites More sharing options...
oldmates260z Posted January 13, 2015 Share Posted January 13, 2015 Can you post a photo of the compressor and its data plate, I may be able to help to where and what to buy. You should be able to buy the parts from Cold Drive if they are available. http://ishop.cooldrive.com.au/ The grinding sound is not good. The compressor could be seized or seizing. Will need to be re-gassed for sure Quote Link to comment Share on other sites More sharing options...
Casper the friendly ghost Posted January 13, 2015 Author Share Posted January 13, 2015 Here it is.. Quote Link to comment Share on other sites More sharing options...
oldmates260z Posted January 13, 2015 Share Posted January 13, 2015 Was a bit harder than I thought. Suggest you call Cold Drive and ask if they sell kits for them, not sure how lucky you will be. I ended up fitting a Unicla compressor (or a more common brand Sanden will do) on my 260 which I assume will also fit a 280ZX but it looks like the ports come out the rear whereas mine out the top Quote Link to comment Share on other sites More sharing options...
Casper the friendly ghost Posted January 13, 2015 Author Share Posted January 13, 2015 I send an email earlier to ask.. 280zx has got quit a lot of room.. Maybe with a 90 degree bend on the pipe it will be no problem. Quote Link to comment Share on other sites More sharing options...
