Scoota G Posted January 16, 2012 Posted January 16, 2012 Just arrived from the states and 1/2 price of comparable items. Just wire in a plug and you're set to go. Quote
Moderators Zedman240® Posted January 16, 2012 Moderators Posted January 16, 2012 Nice..runs on 240/50Hz and not 110/60Hz? Quote
Scoota G Posted January 16, 2012 Author Posted January 16, 2012 Yes dimitri, it was the only 220 240 volt one i could find. The others looked better with their camo design but i tried this on today and it works a treat. $550 delivered. Quote
nat0_240_chevZ Posted January 23, 2012 Posted January 23, 2012 looks like a 'Rothenberger' copy..... how ma?? I Use the rothey alot, pins get expensive here in aus but, not too bad as i re-use them till their 20mm long..... nat0 Quote
zzzzed Posted January 24, 2012 Posted January 24, 2012 I was using a rothenberg for stud pulled for years. But I recently purchased an eagle 2 which is a shit load better. You don't need studs as it welds te pulled its self to the panel. And once you have made the pull iu just twist and it's off. It's cut my repare time in half. Quote
nat0_240_chevZ Posted February 6, 2012 Posted February 6, 2012 yup, use a similar one now, single spot, wire lines and washer or hooks too, all consumables but all money i dont have to pay to use it . nat0 Quote
