mrp69 Posted April 20, 2009 Posted April 20, 2009 Hey guys Im selling my conversion that is currently in my car running and engineered. it is a 3.5L V8 P76 rover motor Alloy with 350 Holley carby come with engine mounts and all wiring Supra 5 speed box with custom bell housing and clutch (W58) Custom tailshaft to suit R180 or R200 diff R200 3.33 Rear Diff Centre ( no yolks or axles) exhaust to suit that is currently in car and clears everything Kms on motor are unknown to me but is a very strong motor. Motor has been in the car since 2002 as per Victorian Engineers papers and wasnt a problem being engineered in NSW also this motor package can be engineered with standard brakes. this is everything from radiator to diff ASKING $3200 with 3.33 R200 diff lower price if not supplied any questions call me 0425 319 100 peter Quote
stevo_gj Posted April 20, 2009 Posted April 20, 2009 Hey man, did you ever get this bad boy dynoed? Just curious Steve. Quote
mrp69 Posted April 20, 2009 Author Posted April 20, 2009 no dyno but have done a quarter mile run and achieved 15.3 so i cant imagine it being that much its and small v8 just good down low and lot of torque peter Quote
C.A.R. Posted April 20, 2009 Posted April 20, 2009 FWIW if it's a 3.5ltr it's from Rover P6 3500 etc. If it was a Leyland P76 engine it'd be 4.4ltrs - It's a different engine to the Rover 3.5ltr Quote
mrp69 Posted April 20, 2009 Author Posted April 20, 2009 everyone thats seen it says its a p76 besides those motors are old so who know im not a historian Quote
Zeddophile Posted April 21, 2009 Posted April 21, 2009 FWIW if it's a 3.5ltr it's from Rover P6 3500 etc. If it was a Leyland P76 engine it'd be 4.4ltrs - It's a different engine to the Rover 3.5ltr You beat me to it Lurch! P76 is definitely 4.4, and has a wider valley (due to the block height being extended to allow for extra stroke) than the Rover engine, which came in 3.5, 3.9 (sometimes badged as 4.0, but still the same capacity) and 4.6. You can bolt rover v8 intake manifolds onto a P76 4.4, but there needs to be spacers put on the heads to account for the width difference. There are a couple of other differences to, I think from memory the valve gear on the head is different for one... The rocker covers were tin ones, and a much squarer shape than the rover ones, which IIRC were alloy even in the early rounded style. The Leyland rocker covers also had smooth flat tops with no branding on them, while the rover ones had fins cast into the alloy. Rover 3.5 is around 160hp and 210 ft/lb in standard form. Bit of a slug pushing a range rover around (especially when down to 7 cylinders!), but quite fun in a lighter car. Quote
