T.A.P
Everything posted by T.A.P
  1. Great stuff, please lmk when it's in.
  2. As the tittle says. Let me know if you have one in good nick.
  3. Much too young. RIP
  4. I might have one, I'll let you know tomorrow.
  5. Ive heard differently, charges apply only when the item itself is worth over 1k
  6. Bahahahha shouldnt you? Nah I was driving for chillie mussels and noticed loud clunks from the rear end (pretty sure it was the diff banging up) under acceleration (going down hill was less clunking but top hill was loud as) no noise when I took my foot off the gas pedal or deceleration, sounds to me like the mount and strap are shot. I'll recheck all the bolts and u-joints tomorrow, just to make sure. Anyway if anyone in WA is interested please let me know by tomorrow.
  7. Anyone in WA wants to swap their diff mount to RT improved diff mount and modified top mount? Ive contacted Brian over the States and he can ship two of each part for the same shipping price which is $48.86 USD. Each mount costs $60 USD and each modified top mount is $28USD. We're looking at $112.43 USD shipped per kit. Let me know ASAP. Cheers Heres the link to what Im talking about: http://www.technoversions.com/DiffMountHome.html
  8. My 50amp alternator wasnt squeezing enough juice to drive the add-ons that Ive installed so the only remedy would be to upgrade the alternator. Ive done some research on the net in regards to which alternator is a good candidate, the bolt-ons like the ones from the 280zx is only giving about 60-70amp which is alright but not quite enough so I decided to buy a universal alternator from eBay for the cost of $139 plus shipping. This one gives 110amp which is more than enough to drive any modern car and still has plently of power left. It can be used as 1-wire or 3-wire, so connection is quite easy if you choose to go the 1-wire route, the 3-wire is a little tricker but nothing of rocket science. The only nagative thing about this Alt is that you will need to modify the mount so it can be fitted. Here are some pictures if any one wishes to use them as reference when swapping theirs. The F and N connector for 3-wire Old alternator Side by side comparation Here I shaved the mount off using an angle grinder, keep grinding away until the mount is about 16mm in thickness then test fit and grind more if needed to align the pulley straight in line with the belt. The boss decided to take a quick nap... Heres a T female connector hooked up, white/black wire is the the recharge lamp (F or L) and the double red/black wires are for the signal (S or N) connector. Since the alt uses internal regualtor the external one is no longer required. However small adjustment s are needed to make the lamp and signal wire work as they should. The white wire needs to be connected to the yellow - this connects the signal continueity. The blue wire needs to be connected to the white/black wire by a diode (the stripe end of the diode to the white/black wire) - this connects the lamp continueity. The F or L connector goes to the #1 pin on the alt and the S or N goes to pin #2. The optional step is to fabricate a rear mount for the alt since the old one uses double mount, front and rear. I got a piece of steel about 1.5mm thick cut and shape it to the requirements and viola. This can be skipped as the alt is already held very tight by the front mount and the adjustable mount but for peace of mind this step is recommended. All hooked up, this is a good time to upgrade the current wiring system if you havent already done so. The stock harness can not handle the extra amp and might burn out, 4 gauge wire is plenty here. Lamp lights up at Ign and off after the car started. The alt is giving ~ 13V at idle (car is idling at 600 cold-700rpm hot) and gives out 14.8V at ~800rpm. Headlights now brighter, car response is much better. Overall highly recommended upgrade over the old alt. Heres are some links that might be of help. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=180735638415 - Alternator http://www.atlanticz.ca/zclub/techtips/alternatorswap/index.html - Good read, heaps of info on re-wiring
  9. Bahahaaha thats gold!!!
  10. Maybe you should post pictures of the rust areas so buyers know what is to be expected.
  11. buuuuuuuuump.......
  12. I think they're for the rear demister and hazard switch and power to the fan.
  13. Ive just asked aus300zx forums and got a confirmation that the spline/diameter of the 300zx is 34 x 17.5mm respectively. How on Earth NRG states that their SRK-140H adapter fits the earlier Zs and later Zs is beyond me. Now how do I go about purchasing a NRG short hub...
  14. Ok Ive done some research and a lot of people say that pretty much all Nissan cars use the same spline count/ diameter . Nothing concrete yet...
  15. Sam depends on how good you are with modification, its possible but do you really want to do it? The finish might not look that good, but if you decided to do it a deep dish wheel will be a better choice. Ned, Im also thinking about doing that but with a quick tilt instead of the quick release, its faster and more practical
  16. In case you haven't decided yet the 240sx or 300zx hub adapter will fit to the Datsun 260z. If you follow this link you will see they all use the same adapter part #. http://crowderscustomizing.com/index.php?l=product_list&c=1174
  17. NVM.
  18. Rear quarters and rear hatch and the outer strip of the rear hatch are good, I have not try any other. Actually if you trim off the outer rubber of the MSA's (just the under half) the doors close very well, no out of place and no slamming.
  19. Yea I saw that one, killer price plus killer postage :-\
  20. They are recent purchase. Yea Scott's rubbers are very good, soft and perfect fit.
  21. I think they will settle, after cutting abit off the strip I was able to close them but they werent flush with the body and were hard to close. However they seemed easier to close today so I cut a little more where the rubbers sort of "swashed in" because of being tightly sandwiched between the door and the body, I moved the latches abit to the inside of the car and now the doors are flush with the body. Still hard to close but they are flush. I'll wait for a month or so and see how it goes. If the slamming continues I'll order some strips from Scott's, just received some for the quarter windows and hatchs strips and his rubbers are softers than MSA's.
  22. Im chasing two small and one big blank cover plates for the centre console. Please let me know if you have any laying around, cheers.
  23. Does anyone else has problem with their weatherstrips from MSA? After fitting the door weatherstrips I cant close the doors so I had to cut a portion of the outer strip from the driver side kick to the middle of the datsun kick plate. I still cant close them properly unless I use excessive force and slam it, and I mean really slam it. Hopefully the strips gonna "settle" in otherwise the doors gonna fall off soon...
  24. There was a custom set on eBay. They look nice but no clock and volt/amp. http://cgi.ebay.com/ebaymotors/Datsun-240Z-260Z-280Z-Autometer-Gauges-Stock-Dash-Speedometer-Tachometer-/370544724918?pt=Motors_Car_Truck_Parts_Accessories&hash=item56462fcbb6
  25. May be we can save on postage? Ash do you think 2 12inch fans enough for air-con system?
