jesseminnis Posted October 24, 2012 Posted October 24, 2012 Hey guy, I'm in need of some parts to finish my Z31...if anyone can help me please message me or leave your number thanks. Parts: 5-spd Transmission, from bell housing to tail, including all bolts, washers, pins, etc. Manual shifter and its hardware. Dust plate (2) 5-spd drive shaft 5-spd flywheel Flywheel to crank bolts Speedometer cable analog Speedo (NOT SURE IF NEEDED) Speedometer pinion O-ring (NEW) 5-spd Transmission mount and cross member 5-spd Clutch pedal assembly 5-spd Brake pedal assembly Clutch master cylinder Clutch dampener. (sub a 280ZX driver's side front brake line) Clutch hydraulic line from 5-spd car Front Downpipe from 5-spd car 5-spd ECCS (computer) (makes for easier tuning) Clutch pressure plate Clutch pilot bushing Clutch throw-out bearing Thanks you in advance to anyone that can help. Quote
pauls Posted October 25, 2012 Posted October 25, 2012 although in Melbourne, should be able to assist. some parts listed in classifiedz on zdriver.com.au Quote
dat2kman Posted October 26, 2012 Posted October 26, 2012 Can supply a Z31 five speed trans complete, straight bolt in, correct bell housing. Quote
carter6787 Posted November 7, 2012 Posted November 7, 2012 Do you still need the parts? I am wrecking a complete 280zx and I live in Beenleigh not far from you. You call call me on 0419833969 anytime Quote
