I hope you didnt pay too much for them...
They arent really worth anything.
From the part numbers in the picture (assuming its correct)
They are from a Toyota 2TGEU engine
188 cc/min @ 2.25BAR 2.8 Ohm impedance.
for a worked turbo L28 you should be looking at 400cc injectors as a minimum
Stock 280zx injectors flow 188cc.
Easiest upgrade is go for VL Commo RB30 Turbo injectors, BUT you will need a ecu to control them.
If your stock injects are no goid, i got a set of cleaned and flowed ones here, as well as a set of Bosch Motorsports, used.
