Hello dear Z owners,
I am enquiring as to whether anybody else here has ever dealt with a setup such as this?
-Twin throttle body
-Megasquirt/WOLF3D ECU (whichever's cheaper)
-Stock Twin SU manifold
-Loom
-280ZX distributor
For those who are experienced/knowledgeable; approximately how much will it cost me labor wise and me purchasing the parts: loom, ECU, throttle bodies?
I am really assessing my current situation and optional solutions out there to properly cure my Z as I've already spent more than I had forecasted simply on the engine (I could have done an RB25 conversion with Engineering).
Thanks heaps gentlemen.
Do you mean the twin butterfly throttle body that was fitted to some  Nissan 280zx's?
If so dont bother, their cfm flow rates are lesser than a single stock 280zx throttle body.
Easy way to go is a Ford XF falcon TB, cheap it wreckers, not so cheap at new parts.no i do not have a Falcon TB on
race car, it is just a plain simple stock one ( eh eh !)
you can use your twin su manifold and have injector holes drilled and injector bungs fitted, then use z32 throttle bodies there 50mm or so and just mount up your throttle position sensor where the z32 one goes. i am planing on doing this soon when i run my turbo
