53-681 Posted March 4, 2012 Posted March 4, 2012 (edited) Hello all, I am after a factory turbo manifold for my L26. Kind Regards Edited August 7, 2021 by 53-681 Privacy Quote
dat2kman Posted March 4, 2012 Posted March 4, 2012 What casting number are you chasing, ie a letter and a two digit number, in raised lettering cast into the top of log plenum. Quote
53-681 Posted March 4, 2012 Author Posted March 4, 2012 Just after anything that will work optimum with my L26... Quote
dat2kman Posted March 4, 2012 Posted March 4, 2012 Just bolt on to your n42 any old L series injection manifold, forced induction will make it work, use the stock TB Just run VL commo injectors, as a starting point, and a reasonable ECU, not stock. Dont even try to use injectors from the stock manifold. Quote
53-681 Posted March 5, 2012 Author Posted March 5, 2012 Hi Dat2Kman, I'm not planning on using EFI/ECU... Will this still work? Am after a carby setup Quote
benny Posted March 5, 2012 Posted March 5, 2012 Sam dont bother with doing a carb turbo setup will end up costing more in the end!! You can find a cheap used ECU on ebay the rest can be picked up cheap!! Quote
53-681 Posted March 5, 2012 Author Posted March 5, 2012 But ECU is going to kill my pockets Benny L28e ECU is not designed for my engine and buying a wolfenstein 3d or a megasquirt one is even more $$$ p.s. I know its not bj blazkowicz Quote
benny Posted March 5, 2012 Posted March 5, 2012 why wont it work with your motor?? if anything it may supply a little extra fuel... no biggie!! Quote
53-681 Posted March 5, 2012 Author Posted March 5, 2012 arrgh I just want a 2-seater now!!! My night hormones are kicking in... Must be a full moon tonight Quote
