Pedro Posted February 27, 2012 Posted February 27, 2012 Ok. I have a street zed. basically when i painted the zed some years ago now i acid dipped most panels i could but didnt do the bonnet. sure enough the bonnet is bubbling in a couple of places (rust). So - just got a quote to dip it at around $350/400. eek. then it will need bodywork done - eek $$ to fill in the bog that falls comes out under dipping which i am sure is in a few places. Then paint. - this cost expected. So its going to be a blowout. I was thinking maybe i should get a fibreglass bonnet for $x and just get that painted? i think new they are in the $4-500 range but i could be wrong. Any thoughts on this matter? obviously i would want it to open and shut like the stock hood does. not sure which way to go on this one, i do want a good long term solution. Quote
Riceburner Posted February 27, 2012 Posted February 27, 2012 That's the exact reason I'm going to Fibreglass, I was starting to get surface rust on the edges of the frame. Now with Fibreglass I won't have that issue ever again. Weight saving helps too Quote
Roberto Posted February 27, 2012 Posted February 27, 2012 Or get a carbon fiber bonnet and then no $$$ and time spent on painting. I am considering this but still undecided. Quote
Pedro Posted February 28, 2012 Author Posted February 28, 2012 also is fibreglass (or carbon) safe in a frontal car accident? any real difference? Quote
PZG302 Posted February 28, 2012 Posted February 28, 2012 also is fibreglass (or carbon) safe in a frontal car accident? any real difference? Depends what you hit..... If it's another car or something solid, fibreglass will break and shatter into tiny pieces or a combinatioon of big and little pieces, but at least it's easy to replace, I know this from personal experience Steel bonnet will fold and dent like steel does, so no real difference - in both cases the bonnet is buggered, with steel you can hit it with a hammer to straighten it out, with fibreglass you replace it. If it's a pedestrian, well steel, fibreglass, carbon it doesn't matter they are going to have a bad day...... Quote
