drzoidberg Posted January 8, 2012 Posted January 8, 2012 hey fellas, Any one ever played with the factory 280zx efi system? is it tunable at all? cheers Quote
luvemfast Posted January 8, 2012 Posted January 8, 2012 Check out the AtlanticZclub website. You'll find a few tricks there, but basicall, The stock ECU is not tunable. Quote
drzoidberg Posted January 8, 2012 Author Posted January 8, 2012 wow that atlantic z site had some great stuff on it, cheers. Quote
dat2kman Posted January 8, 2012 Posted January 8, 2012 Factory ecu is getting old, main issue is knowing what does what, the values of components, and which way you need to go to change things. In short, dont bother, instead try bigger injectors, and combine with variable resistors in the afm temp circuit, and the water temp circuit to clip the pulse rates. They work on group fire, by altering/reducing pulse amount with bigger injectors you can sort of alter fuel delivery, combine with a decent camshaft, good exhaust system, they can be made to work ok. I have stumbles in mine at approx 4000 rpm, but above that to 7800 it is all good. Other issue is the intake plenum flows different cfm air down each runner front to back, resulting in lean outs and burnt pistons. Intake needs to be airflowed and matched cfm per runner A decent fuel pressure reg helps too. Otherwise, just buy a aftermarket ecu,,,,,, i am selling a Autronic sm4, brand new, $2100 Quote
drzoidberg Posted January 9, 2012 Author Posted January 9, 2012 thanks mate but aftermarket ecu stuff is a bit out of my price range. ill play around with trim pots on the water temp sensor and have a go at puting a cressida afm in and see how it goes, just for the fun of it. Quote
luvemfast Posted January 9, 2012 Posted January 9, 2012 thanks mate but aftermarket ecu stuff is a bit out of my price range. ill play around with trim pots on the water temp sensor and have a go at puting a cressida afm in and see how it goes, just for the fun of it. Thats what its all about. Playing Quote
Six_Shooter Posted January 11, 2012 Posted January 11, 2012 Delco (Holden/GM) ECM conversions have been done with great success. Tunable and reliable. Quote
drzoidberg Posted January 12, 2012 Author Posted January 12, 2012 hmm thats interesting, vn 6cyl fuel injection? do you know much about the conversion? Quote
Six_Shooter Posted January 13, 2012 Posted January 13, 2012 hmm thats interesting, vn 6cyl fuel injection? do you know much about the conversion? Intimately. However, my hands on, is with North American products, which differ slightly from the Australian counterparts. There is at least one Australian Delco conversion though. Now, they did a few things differently than I did, and I think it was more to use what they had around. http://delcohacking.net/forums/viewtopic.php?f=16&t=998 The 280Z Dizzy can be used to trigger a GM Delco ICM (Ignition Control Module), which is how I did my initial conversion, mostly because I ran out of time to get the DIS on, before Zfest that year, I got it running the day before, then drove it about 150 KMs round trip with a very rough tune! It drove fine though, just need some work to get it better (and lock out the dizzy ). Quote
drzoidberg Posted January 15, 2012 Author Posted January 15, 2012 that looks like fun, i like how they got the crank position sensor going. might consider having a crack at it later down the track. Quote
