Steering Wheel Restoration DIY (Datsun 240K Skyline)
Posted (edited)
Hello everyone,
I've spent Christmas eve spending time restoring my 260Z's steering wheel like a boss! Seeming as I don't celebrate Christmas  ::)
Now this is a cheap DIY process which only takes a couple of hours, so please don't expect so much from the results, though I must say that I'm pleased with it myself.
Items used:
-22mm socket
-Steel Wool
-Masking Tape
-Newspaper
-3M stage 3 satin black for vinyl
Before Photos:
Here is the procedure I've taken:
1. First, unbolt the steering wheel from the steering column
  -Unplug the battery
  -Push the horn button in and twist anti-clockwise
  -Undo the 22mm bolt holding the steering wheel
  -Pull steering wheel off
2. Use steel wool and clean off the rust clots from the center/dish metal pieces
After using the steel wool
Make sure you use the steel wool stuff on the back as much as possible as well. I didn't bother taking out the back plate; I just worked around it. (It is a quick weekend job :) )
3. Wrap masking tape around the metal center/dish. Make sure its all thoroughly covered
Lay some newspapers underneath the wheel to prevent black paint going on your floor/tiles (Save face from the missuz :P )
4. Spray 3M Stage 3 Vinyl Satin Black spray paint on your steering wheel
  -First spray underneath
  -Then spray on top
Note: Wait about 1 hour for each side to dry before switching over
  -After drying, scrutinize the wheel to ensure that there aren't any un-painted areas remaining. If there are, just lightly spray over them and wait another hour to dry.
5. Paint the little inside horn buttons in a similar manner
6. Take photos and enjoy the end results. Don't forget to post them up on www.viczcar.com
With the little horn buttons attached
Installed in the Z
Merry Christmas dear Z drivers/owners :D
Edited by 53-681
Privacy
Nice work! I'm curious about your wheel though - I'm thinking it's perhaps off a SSS or 240K - I also have an early 260 & my wheel is black foam padded & has a different horn pad. Yours is a far nicer looking wheel IMO.
