zedfan86 Posted July 2, 2011 Posted July 2, 2011 Hi all, Chasing some round tops, manifolds and linkages for a project 240z I'm doing up (with a L26). The linkage i have at the moment ends at the firewall "bracket". Also need an air filter housing. Any condition considered. Hopefully someones got something lying around. I'm very keen to get hold of some good ones i can just bolt in because this is all i need to get the zed running, everything else is ready to go, well mechanically that is. Cheers Matt Quote
1600dave Posted July 2, 2011 Posted July 2, 2011 I have an early manifold, with some linkages (everything from manifold to carbs, but not the rod from firewall to manifold). Also has the fuel "hard" lines. I bought a set of "3 screw" round tops off this forum a few weeks back but only want the actual carbs for my Datsun Fairlady H20 engine conversion. Just cover the cost of postage from Newcastle, NSW and the leftover manifold stuff is yours. I was going to bead blast it and stick it on eBay but I'm too lazy . Yell out if you want pics. Quote
