Pacey Posted April 11, 2011 Posted April 11, 2011 Hi all Wondering if anyone has come across a larger AFM for a 280zx. I have heard there were some on RX7's and some early BMW's ?? but cant find any around.. I am wanting to increase the air capacity into the Z, Just a bit of an experiment... cheers Quote
luvemfast Posted April 11, 2011 Posted April 11, 2011 I remember reading something about a Cressida upgrade. Here tis http://atlanticz.ca/zclub/techtips/afm/sizeupgrade/index.html Quote
Pacey Posted April 11, 2011 Author Posted April 11, 2011 Thanks Simon Good reading. Hopefully I can find one around somewhere. Looks interesting Thanks again Quote
Pacey Posted April 20, 2011 Author Posted April 20, 2011 Well I went to Imalchs on the weekend and picked up a larger AFM 2 x 2.5" $30 from a Toyota. Took it home and did all the tests on it. All tests were exactly the same as the original 280 AFM, i was pleasantly surprised. Even put a voltage through it , and range was the same as the Z.. Put it in the car, Started like a dream, my air fuel gauge was sitting better than it ever had. The only thing I did was clean it and tension the spring three teeth tighter, runs smoother, with more grunt in the top end. There was no need to exchange circuit boards or anything. I'm curious why I haven't been able to find anything on the web about this, especially being a direct change to a larger AFM. If anyone need photos let me know.. Alan Quote
luvemfast Posted April 21, 2011 Posted April 21, 2011 Awesome stuff Alan Any improvement in performance? Quote
. Posted April 21, 2011 Posted April 21, 2011 yes photos please Can you also give more detail regarding the model car it came off. Thanks Quote
Pacey Posted April 21, 2011 Author Posted April 21, 2011 Yeah Definitely an improvement in power, especially top end, I am still dialing it in..but I am wrapped with the difference.. The AFM was from a Toyota, sorry didn't get the model, But it was a four cylinder and the AFM was attached to a air box, and I believe it was a 1999, silly bugger I am, but I was more exited to find the part. but I will go back to Imlachs this Saturday and have a look, ( cause i feel guilty ) but there were at least six there that i saw, $30, not a bad investment in my books. All were labelled with an AIr Flow Meter sticker and a model number etc. I have taken photos of the label and the whole inside of the unit and will post them on in the next couple of days..when I learn how to do it on here.. Talk soon Quote
Pacey Posted April 23, 2011 Author Posted April 23, 2011 Hi Guys wont get a chance to go to Imlachs today being Easter (too many family things to do), see how I go tommorrow. and ill find the model this thing came off. here are the pics of the Toyota AFM, all is still going really well, took it for another drive yesterday and I am still very happy.. Like I mentioned, no need to modify anything just pop it in and away you go..only thing I did was tighten the spring three teeth.. alan Quote
stevofoxono Posted April 23, 2011 Posted April 23, 2011 very interested to find out what model it came off good find mate Quote
Pacey Posted April 24, 2011 Author Posted April 24, 2011 No probs I will go to Imlachs this weekend, cause they are not open due to Easter and find the model for you. There were at least six of them there cause I was searching for a good clean one and came across Toyota after Toyota in a row with them. I do know that it was definitely a four cylinder Toyota, and I'm pretty sure they were from 1999 thru to 2002 ?? And they were all definitely attached to a black air filter box and all AFM had a label saying Air Flow Meter ( have a look at the above photos) I may go buy another this weekend as a spare cant go wrong for $30 Hope this helps a bit, Alan Quote
DatPilot Posted May 2, 2011 Posted May 2, 2011 Just to note, the AFM may be a minor restriction, not the biggest one on the engine. ( i'd say the ECU is the main choke point!!) Excellent work on documenting this though I had my L24e dynoed at 54kw stock, then intalled a Microtec fuel only ECU, had a map sensor, so pulled the AFM out. a few hrs tuning later dynoed at 75kW.... Quote
Pacey Posted May 2, 2011 Author Posted May 2, 2011 Thanks for the info, I will be looking into a management system next. Can I ask which Microtech model you used and if it does six cylinder. Alan Quote
stevofoxono Posted May 3, 2011 Posted May 3, 2011 mate did you end up going past the wreckers and finding out the model for the afm? Quote
DatPilot Posted May 3, 2011 Posted May 3, 2011 I used a Microtech LT-4, very basic (VERY). This was the Laptop PC connection enabled type. The MT-4 was hand controller tuned only. Cost me $300 from another running car (was a wrecked C210 skyline) There are better ones out there though. but as this was my first, being simple and fairly easy to use was ok. Still have the dovumentation/wiring diagrams too. Quote
Pacey Posted May 3, 2011 Author Posted May 3, 2011 Hey StevoFoxono Sorry, no I didn't get a chance to go the wreckers, to busy playin with the car, I'm going there this Saturday to grab a few things, I will check it out for you then, I'll post it on here Saturday arvo sometime. Datpilot Thanks again for the info, yet again something to research for the Z always gets me excited.. Quote
Pacey Posted May 6, 2011 Author Posted May 6, 2011 stevo finally got to the wreckers today, i got my AFM off a 99 Toyota Camry, (4 cylinder, east west motor) just make sure you get the same shape as what i got photos above,, the square shaped plastic covered AFM are MAP versions..and wont work.. Good luck Quote
stevofoxono Posted May 6, 2011 Posted May 6, 2011 thanks mate i recon i'll track it down on monday Quote
. Posted May 9, 2011 Posted May 9, 2011 Got mine on Saturday. Modified it over the weekend and it is now in the car. I haven't tried it yet. A couple of additional notes: The end closer to the air filter on the Toyota item does not have anything to attach the air intake hose. Luckily the bolt pattern matches the adaptor from the original AFM. Be careful though as there is the potential for a hair line gap out to the atmosphere. I used silicone to seal mine. Because this item is from the original AFM it fits in the same place as the old one (no need for any adaption). This adaptor has a restriction in the middle to reduce the flow area down to match the small flap area of the original AFM. Because the Toyota AFM has a larger flap area the restriction on the adaptor is not suitable. I filed mine down to open it up to match the flap area of the Toyota AFM. The end closer to the throttle body on the Toyota is 90mm diameter. You will need an adaptor to down size it to match the fitting between the AFM and Throttle body. My piece here was home made to match my aftermarket throttle body. I was able to get the adaptor from Supercheap. It was a tight fit but I was able to make it work. Sorry I forgot to take photos and now its in I am not taking it out because it took some effort to squeeze it in. Quote
stevofoxono Posted May 10, 2011 Posted May 10, 2011 picked up mine yesterday arvo and put it in today.. Slight problem now tho, my car won't idle. Tried putting the stock afm back in aswell but made no difference. Thought my plugs were fouled so i replaced them but no resolution. Car sounds like its misfiring now.. Its weird cause i touched nothing but the afm and now my z's not driveable, weird coincidence. hoping its just a ignition lead and not something internal Quote
Lynton Posted May 10, 2011 Posted May 10, 2011 Maybe disconnect the battery so the computer resets itself? Lynton Quote
peter mc Posted May 10, 2011 Posted May 10, 2011 G'Day Mate, Try removing the plug from the air flow meter and look at the terminals to make sure that they are still in the right position, some times when you remove them and replace them the terminals slip back into the plug. Also check the wiring behind the plug to make sure you don't have a broken wire. Don't replace any other parts at this stage, as the fault was introduced with the air flow meter. Quote
Pacey Posted May 10, 2011 Author Posted May 10, 2011 Hey guys Sorry to hear you have a couple of issues. I didn't have a problem with the throttle body side of the AFM size, cause I had a larger 70mm throttle body from a Commordore on there, Galderdi you mentioned that the throttle body side of the Toyota AFM was 90mm, this doesn't sound correct, I'm sure mine was 75mm to 80mm no more, I might remeasure it tomorrow and check. Does the Toyota AFM look the same as my pictures ?? Stevo Not sure why you have the idling problem, did it run ok ?? Maybe check the water temp sensor for the ECU, I had this problem recently when the plug came loose, and the car wouldn't idle, was extremely rich. Alan Quote
. Posted May 11, 2011 Posted May 11, 2011 Yeah you are probably right I was working from memory. 80mm does sound right. Yes it is identical to the one in your pic other than the code numbers. Quote
stevofoxono Posted May 11, 2011 Posted May 11, 2011 still no luck.. I've got the camry+280 afm and neither of them make my car work. I've got a feeling its the plug.. would cutting the wires and crimping on the camry plug work? gonna check compression+change over the coil leads tomorrow Quote
