I was about to replace my rear wheel bearings with a rear kit i bought off the forum a few years ago but noticed the inner bearing I've got is actually a sealed unit part number RLS-10 RS, the part number I should have is RLS10-T-C4. Does anyone know if my part number will work fine or not?
hey Mossy, just flick one of the seals out and pack the bearing with grease, you dont even need to put it back ,as a long as the bearing has the same or 2 more ball bearings in it and the dimensions are the same .    cheers Daniel
