Hi
I am ordering a seal kit and there is a lot of confusion.
Could someone please tell me if there is a difference for the seal kit
between 260Z coupe and 260Z 2+2.
The supplier seems to think I need a 280 Z 2+2 kit
Please Help
cheers, peter.
The 280Z was not available in OZ.
Who is the supplier, I ask this as they seem to have no knowledge of HS-30 models in OZ?
Incidently, what exactly are you after when you ask for a seal kit?
Body seals, door seals, window seals, gaskets are also confused with seals.
Mike
There would be no difference in the screen seal.
Door seals would be bigger in the 2+2.
You may be better trying Scotts Old Auto Rubbers in Oakleigh. They stock the complete range of profiles that you need.
Thanks Luke,
On checking several sites, it seems that in the U.S they had a 260Z and 260Z 2+2 with the 2.8 motor and called 280Z and 280Z 2+2.
Peter.
  • 4 weeks later...
I've been told the 2+2 windscreen seal has a slightly longer top than the coupe seal. I found this out when I had to buy one from AllZ in Sydney. He reckons the coupe will fit but the 2+2 fit better.
I bought door seals from Clarke Rubber for a pretty good price but yet to install.
  • 2 months later...
Nope they have the bailey channel which I also bought off them which is good. But I'm talking about the door seals which they sell by the metre. Don't know who they source them from but they had a program on their computer which they let me look through to see what they could supply. Had a few different items and seem to be pretty well suited.
and price wise?
I really need the seals that go in front of the window on the door, the top of the door, the channel and behind...
ok I need just about everything
  • 2 weeks later...
I just got the rear window seal from rare spares $139.
In adelaide we got this mob called "Fitch the rubber man" i got from them the chrome outeer strip seal that seals the glass to the chrome strip 27 each. rare spares want like 50 each.
rear hatch rubber i got it off U12 Pintara of wreckers.
the rest of rubber ill be getting form fitch as they have almost every profile under the sun. other stuff like the rubber that is cliped infront of the door where the window frame bolts up to u can get from nissan $30 each.
Just some information on ordering a seal kit from the U.S.A.
Ordered mid January, finally received early May.
Front and rear screen rubbers o.k
Door seals to short, hatch seal to large.
Top of door seals missing.
Quarter outer window seals missing.
I ordered from America because i was led to believe a complete seal kit
would be supplied.
Lesson learned. go to some more trouble and buy in Aus.
Cheers, peter.
