mossy Posted August 14, 2010 Posted August 14, 2010 I'm starting to do some home plating on all my parts but just wondering were all parts yellow zinc or silver zinc, or was there a mix of both(on the 240z) Quote
Moderators Zedman240® Posted August 14, 2010 Moderators Posted August 14, 2010 I've always seen yellow zinc on restored zeds. Either that or they are painted the body colour as with the low profile headed bolts for the guards. Quote
Zedsabbath Posted August 14, 2010 Posted August 14, 2010 Just looking at my unrestored bits and pieces here... door catches ..................................................................... silver hatch stoppers (with the nylon blocks in them)................... silver hatch stopper wedges........................................................ silver hatch hinges ..................................................................... silver hatch catch (both parts)..................................................... silver dip stick ............................................................................ looks to be silver but gold can look neat carby linkages, quadrants and brackets .............................. gold fuel cap and mating base ................................................... gold bonnet catch (both parts) .................................................. gold hatch boot reinforcers (if you've got them).......................... gold, these are not the door adjusting shims, they keep boot flange in place trouble light....................................................................... gold That's it for the moment Pete Quote
Zedsabbath Posted August 14, 2010 Posted August 14, 2010 "hatch boot reinforcers (if you've got them).......................... gold, these are not the door adjusting shims, they keep boot flange in place" Don't think I explained that properly....it's possible that a lot of boot reinforcers got tossed or just simply left off the car but if we start from the body, the parts for the boots and hinges in their order are..... the body the boot the reinforcer the door adjusting shim the hinge The Reinforcer is a thin metal part shaped at right angles and covers the whole outer flange of the boot to to keep the rubber flange in shape and prevent moisture entering the cavity in the body for the hinge ...it also acts as a solid base for the adjusting shim and or hinge to squeeze against once the bolts are tightened Pete Quote
mossy Posted August 14, 2010 Author Posted August 14, 2010 I know the part you mean, I've got some slightly mangled ones, good info here although I'll have to replate some parts I've done wrong though Quote
