In a 260z, with an R200 long nose it's 22.5 inch's.
What's that, 571.5mm, give or take.
**To clarify, from memory that measurement is centre of the pivot on the "U" on either end of the tail shaft. So, centre hole of the uni to centre hole of the uni either end of the tail shaft.
Just measured my spare 240Z one, from tip to tip as in from diff end flange to end of splined shaft that enters gearbox, 755mm.
